Approving ICX Switches
The ICX switch must be approved so that it can be discovered and monitored by the SmartZone controller.
- Switches which are not registered through registration rules are automatically moved under the Default group.
- If registration rules are not present, the switch is moved to the Default group. These switches are not approved in the Default group and are in the offline state.
- After the switch is registered with the controller successfully, it joins the Default group of the controller. To approve the switch manually, you must move it to a specific group. See Moving the Switches between Groups for more information.
Follow these steps to automatically approve the switch:
