Moving the Switches between Groups
You can move the switches within any group or sub-group in the system hierarchy to manage it.
Approval of Switches
- Switches which are not registered through Registration Rules are moved under the Default Group.
- If Registration Rules are not present, the switch is moved to System Domain.
- These switches are not approved in the System Domain and are in the offline state.
- To approve the switch, you must manually move it from System, to another domain or subgroup, or ensure that registration rule matches.
