You can view the detailed status and result of the firmware update to a switch. You can also view a history of firmware upgrades that were previously carried out on the switch.
From the left pane, select
Switches.
The
ICX Switches page appears.
Select the switch or group. Then select the
Firmware History tab.
The
Firmware History tab is displayed.
Figure 63
Viewing Firmware History
You can verify the status of the upgrade from the
Upgrade Job Status section which displays the time, switch ID, firmware version, image name, status and failure reasons (if any) for the upgrade.
The
Firmware Upgrade History section displays the time of the pervious upgrade operations, and firmware versions to which the upgrade was done.
