Scheduling a Firmware Upgrade
You can upgrade or downgrade the firmware version of a switch or multiple switches that you are monitoring. You can upgrade the firmware on demand or schedule a firmware update for a list of selected ICX switches.
Upload a valid ICX firmware which is greater than version 8.0.80 to the controller.
To upgrade the firmware for a group of switches, you must select multiple switches at the same time and perform steps 3 to 7. For more information on uploading the switch firmware, see
Uploading the Switch Firmware to the Controller
Ensure you sync the controller to the NTP server during installation. You can also do this from
Only firmware versions later than ICX 8.0.80 are supported.
