Configuring Traffic Analysis Display for Top Clients
Using traffic analysis you can measure the total volume of traffic
sent or received by Clients. You can view historical and real-time data of the Clients. The
chart displays:
- Bytes—Frequency and number of clients connected to the AP
- OS Type—Types of OS the associated clients are using
- Application—Throughput the applications use
You must configure the Client settings to view its traffic analysis.
To configure the Client settings:
- From the Clients area, click settings
. Figure 18
appears.Figure 18 Client Setting Form
- In Show top, enter the number of Clients for which the traffic must be analyzed. Range: 5 through 20.
- Select the Type of display you want to view. For example, Chart or Table.
- Select the required Client identification option to be displayed. For example, Name, MAC or IP.
- Click OK.
