Creating Zone Templates
To create a zone template:
  1. From the application select, System > Templates > Zone Templates.
  2. Click Create, the Create Zone Template form appears.
  3. Enter the template details as explained in Table 9.
  4. Click OK.
Table 9 Zone Template Details
Field Description Your Action
General Options
Zone Name Indicates a name for the Zone. Enter a name.
Description Indicates a short description. Enter a brief description
AP Firmware Indicates the firmware to which it applies. Select the firmware.
Country Code Indicates the country code to ensure that this zone uses authorized radio channels. Select the country code.
Location Indicates generic location. Enter the location.
Location Additional Information Indicates detailed location. Enter additional location information.
GPS Coordinates Indicates the geographical location. Enter the following coordinates in meters or floor:
  • Longitude
  • Latitude
  • Altitude
AP Admin Logon Indicates the admin logon credentials. Enter the Logon ID and Password.
Time Zone Indicates the time zone that applies. Select the option:
  • System Defined: Select the time zone.
  • User defined:
    1. Enter the Time Zone Abbreviation.
    2. Choose the GMT Offset time.
    3. Select Daylight Saving Time.
AP IP Mode Indicates the IP version that applies. Select the option:
  • IPv4 only
  • Dual
Cluster Redundancy Provides cluster redundancy option for the zone.
Cluster redundancy is supported only on SZ300 and vSZ-H.
Select the required option:
  • Zone Enable
  • Zone Disable
Radio Options
Channel Range Indicates that you want to override the 2.4GHz channel range that has been configured for the zone. Select Select Channel Range (2.4G) check boxes for the channels on which you want the 2.4GHz radios to operate. Channel options include channels 1 to 11. By default, all channels are selected.
DFS Channels Allows ZoneFlex APs to use DFS channels. Select the check box.
Channel Range (5G) Indoor Indicates for what channels want the 5GHz radios to operate. Select the check boxes.
Channel Range (5G) Outdoor Indicates for what channels want the 5GHz radios to operate. Select the check boxes.
Radio Options b/g/n (2.4 GHz) Indicates the radio option 2.4 GHz configurations. Select the following options:
  • Channelization—Set the channel width used during transmission to either 20 or 40 (MHz), or select Auto to set it automatic.
  • Channel—Select the channel to use for the b/g/n (2.4GHz) radio, or select Auto to set it automatic.
  • TX Power Adjustment—Select the preferred TX power, if you want to manually configure the transmit power on the 2.4GHz radio. By default, TX power is set to Full/Auto on the 2.4GHz radio.
    If you choose Min, the transmit power is set to 0dBm (1mW) per chain for 11n APs, and 2dBm per chain for 11ac APs. If you choose Max, the transmit power is set to the max allowable value according to the AP's capability and the operating country's regulations.
Radio Options a/n/ac (5 GHz) Indicates the radio option 5 GHz configurations. Select the following options:
  • Channelization—Set the channel width used during transmission to either 20, 40, 80, 80+80 or select Auto.
  • Channel—For Indoor and Outdoor, select the channel to use for the a/n/c (5GHz) radio, or select Auto.
  • TX Power Adjustment—Select the preferred TX power, if you want to manually configure the transmit power on the 5GHz radio. By default, TX power is set to Full/Auto on the 5GHz radio.
AP GRE Tunnel Options
Tunnel Type Indicates the support for NAT. Choose the required tunnel type:
  • Ruckus GRE and select the GRE Tunnel Profile.
  • SoftGRE and
    • select the GRE Tunnel Profile
    • select AAA Affinity, which is applicable only for proxy AAA.
    If you select AAA Affinity, you must enable Force Disassociate Client while creating the Soft GRE Profile.
  • SoftGRE+IPsec and
    • select IPSec Tunnel Profile
Syslog Options
Enable external syslog server for Aps Indicates if an external syslog server is enabled. Select the check box and update the following details:
  • Server Address
  • Port
  • Facility for Event
  • Priority
AP SNMP Options
Enable AP SNMP Indicates if the AP SNMP option is enabled. Select the check box.
SNMPv2 Agent Indicates SNMPv2 Agent is applied.
  1. Click Create and enter Community.
  2. Select the required Privilege: Read or Write.
  3. Click OK.
SNMPv3 Agent Indicates SNMPv3 Agent is applied.
  1. Click Create and enter User.
  2. Select the required Authentication:
    • None
    • SHA
      1. Enter the Auth Pass Phrase
      2. Select the Privacy option. For DES and AES options, Enter the Privacy Phrase.
    • MD5
  3. Select the required Privilege: Read or Write.
  4. Click OK.
Advanced Options
Channel Mode Indicates if location-based service is enabled. Select the check box and choose the option.
Auto Channel Selection Indicates auto-channel settings. Select the required check boxes and choose the option.
Background Scan Runs a background scan. Select the respective check boxes and enter the duration in seconds.
Smart Monitor Indicates AP interval check and retry threshold settings. Select the check box and enter the duration and threshold.
AP Management VLAN Indicates the AP management VLAN settings. Choose the option. If you select VLAN ID, enter the VLAN ID that you want to assign (valid range is from 1 to 4094). To keep the same management VLAN ID that has been configured on the AP, click Keep AP's settings.
ATTENTION
For standalone APs, set the AP ethernet port to trunk before changing the AP Management VLAN settings.
Rogue AP Detection Indicates rogue AP settings.
  1. Select the check box and choose the options:
    • Enable events and alarms for all rogue devices
    • Enable events and alarms for only malicious rogue devices of selected types and choose the Rogue Type:
      • SSID Spoofing
      • Same Network
      • MAC Spoofing
    • Select the Protect the network from malicious rogue access points check box.
DoS Protection Indicates settings for blocking a client. Select the check box and enter the:
  • duration in seconds to Block a client for
  • number of repeat authentication failures
  • duration in seconds to be blocked for every repeat authentication failures.
Client Load Balancing Balances the number of clients across APs. Select the check box and enter the threshold.
Band Balancing Balances the bandwidth of the clients. Select the check box and enter the percentage.
Location Based Service To disable the LBS service for this AP group, clear the Enable LBS service check box. To use a different LBS server for this AP group, select the Enable LBS service check box, and then select the LBS server that you want to use from the drop-down list. Select the check box and choose the options.
Client Admission Control Indicates the load thresholds on the AP at which it will stop accepting new clients.
Client admission cannot be enabled when client load balancing or band balancing is enabled.
Select the Enable check box 2.4 GHz Radio or 5GHz Radio and update the following details:
  • Min Client Count
  • Max Radio Load
  • Min Client Throughput
AP Reboot Timeout Indicates AP reboot settings. Choose the required option for:
  • Reboot AP if it cannot reach default gateway after
  • Reboot AP if it cannot reach the controller after
You can select a zone from the list and edit, clone or delete its template by selecting the options Configure, Clone or Delete respectively.
