Viewing Statistics for SoftGRE Core Network Tunnel
To view Stats for SoftGRE Core Network Tunnel:
  1. From the left pane, select Report > Core Network Tunnel Stats. The SoftGRE page appears.
  2. Update the parameters as explained in Table 48.
  3. Click:
    • Load Data— To view the report in the workspace.
    • Export CSV—To open or save the report in CSV file format.
Table 48 SoftGRE Core Network Tunnel Parameters
Field Description Your Action
Time Period Indicate the time period for which you want to view the report. Move the slider to set the duration.
Data Plane Indicates the Data Plane. Select the Data Plane.
Gateway IP Address Indicates the gateway IP Address. Enter the gateway IP address.
MVNO Name Indicates teh mobile virtual network operator name. Choose the MVNO name.
Table 49 contains the report based on the statistics for SoftGRE core network tunnel.
Table 49 SoftGRE Core Network Tunnel Attributes
Attribute Type Description
Time Long Bin ID, which is stamped at a 15 minute interval. For example, 10:00, 10:15.
TX Bytes Long Indicates the number of bytes sent.
RX Bytes Long Indicates the number of bytes received.
TX Packets Long Indicates the number of packets sent.
RX Packets Long Indicates the number of packets received.
Dropped Packets Long Indicates the number of packets dropped.
