Creating a WLAN Group
To create a WLAN group:
- In the Wireless LANs page, from the System tree hierarchy, select the zone where you want to create a WLAN Group.
- Click the add
button. The Create WLAN Group page appears.
- Enter a Name and Description for the WLAN group.
From the
Available WLANs list perform one of the following option:
- select the required WLAN and click the Move button. It will appear in the Selected WLANs list.
- click the add
button to create a new WLAN service. The Create WLAN Configuration page appears. Refer Creating a WLAN Configuration.
NOTETo edit or delete a WLAN configuration, select the WLAN from the Available WLANs list and click Configureor Delete
respectively.
- Click Next, The Create WLAN Group form appears.
- Click OK.
You can also edit, clone, and delete WLAN group by selecting the options Configure
