Printing the Guest Pass
After you generate the guest pass, you can print the guest pass information, which contains the guest user information and instructions on how to connect to the hotspot, and give it to the guest user.
If your browser is blocking pop-ups, make you temporarily disable the pop-up blocker so you can view and print the guest pass.
Follow these steps to print a guest pass.
You have completed printing the guest passes.
Figure 52
What a guest pass printout looks like
