Working with Access Points
- Overview of Working With Access Points
- Hierarchy Overview
The hierarchy helps in specifying which AP groups or APs provide which WLAN services. - Working with AP Zones
An AP zone functions as a way of grouping Ruckus APs and applying a particular set of settings (including WLANs and their settings) to thise group of Ruckus APs. Each AP zone can include up to 27 WLAN services. - Working with AP Groups
AP (access point) groups can be used to define configuration options and apply them to groups of APs at once, without having to individually modify each AP’s settings. - Monitoring Zones and AP Groups
When you select a System, Zone, or AP Group from the hierarchy tree, respective contextual tabs appear at the bottom of the page. - Viewing Modes
You can view System, Zone, and AP Group-level information by selecting one of the following View Mode options: - AP Status
The real-time status of the Access Points are classified as follows: - Configuring Access Points
You can configure an Access Point. - Managing Access Points
