Restoring Configuration to a Single Node in a Cluster
Follow these steps to replace the configuration of a single node in a cluster.
If the node that you want to replace is still functioning, follow these steps to remove the node.
- Choose a controller that will remain in the cluster.
- Log on to that controller's web interface as an administrator.
- Go to .
- Locate the node that you want to replace.
- Click Delete to remove the node from the cluster.
If the node that you want to replace is out of service, you will need to shut down the node before you can replace it. Follow these steps.
- On the node that you want to replace, log on to the CLI as a system administrator.
Run the enable command to enable privileged mode on the
CLI.
ruckus> enable Password: ******** ruckus#
- (Optional) Back up the current controller system.
On the node that you want to replace, run the
shutdown command.
ruckus# shutdown
- Log on to the controller web interface as a system administrator.
- Go to .
- Locate the node that you want to replace,
- Set up the node as a new controller, and then join the existing cluster. For step by step instructions, see the SmartCell 200 Getting Started Guide.
You have completed restoring configuration to a single node in the cluster.
