Step 2: Back Up the Cluster from the Controller CLI
Cluster backup creates a backup of the entire cluster.
Follow the steps to back up the cluster from the controller CLI.
- Log on to the controller CLI as a system administrator.
Run the
enable command to enable privileged mode on the CLI.
ruckus> enable Password: ******** ruckus#
Run the
show diskinfo command to determine the current disk size of the node.
To complete the cluster backup successfully, the /mnt directory must have at least 50GB (53,687,091,200 in 1K-blocks) of free disk space.
ruckus# show diskinfo Filesystem 1K-blocks Used Available Use% Mounted on rootfs 4128448 315520 3603216 9% / /dev/root 4128448 315520 3603216 9% / /dev/sda1 2064208 97208 1862144 5% /boot /dev/mapper/vg00-lv00 41276736 5646756 33533240 15% /mnt tmpfs 1048576 696 1047880 1% /tmp tmpfs 3066864 0 3066864 0% /dev/shm
Run the
backup command to start the backing up the current cluster.
ruckus# backup Do you want to backup system in this context (yes/no)? yes Backup process starts. Backup process has been scheduled to run. You can check backup version using 'show backup'.
- Run the show backup command to verify that the cluster backup file has been created successfully.
Parent topic: Backing Up and Resorting the Cluster
