Applying a WLAN Template
You can apply only WLAN-related configuration to an AP zone using a WLAN template.
Follow these steps to apply a WLAN template:
- From the Wireless LANs page, locate the zone where you want to apply the WLAN template.
- Click More and select Apply WLAN Template, the Apply WLAN Template dialog box appears.
- From the Select a WLAN template drop-down, select the template.
- Click OK, a confirmation message appears asking to apply the wlan templates to the zone.
- Click Yes, a confirmation message appears stating the template was applied
successfully.
You have completed applying WLAN template to the AP zone.
