Exporting Zone Templates
You can export a zone template.
To export a zone template:
- From the application select, System > Templates > Zone Templates.
- Select the zone template that you want to export and click Export Template.
- A pop-up appears prompting you to Open or Save the zone template file
with .bak extension. Click:
- Open—To view the template file
- Save—Select the destination folder where you want to save the template file and then click Open to view it.
