Working with Zone Templates
In 3.6 SCG200-C is supported. SCG200-C is the SCG200 model without the internal DP functions. If Ruckus GRE tunnel is enabled, upgrade to SCG200-C is blocked and the following message appears:
There exists a Zone template [TEMPLATE_NAME] with RuckusGRE tunnel is applied
You can create, configure, and clone zone templates
