Configuring Traffic Analysis Display for WLANs
Using traffic analysis you can measure the total volume of traffic sent or received by WLANs.
You can view historical and real-time data of the WLANs. Throughput and the number of clients connected to the WLANs are displayed in a bar chart. You must configure the WLAN settings to view its traffic analysis.
To configure the WLAN settings:
- From the WLAN area, click settings
. The following window appears.
Figure 17 WLAN Settings Form
- In Show top, enter the number of WLANs for which the traffic must be analyzed. Range: 5 through 20.
- Select the Type of display you want to view. For example, Chart or Table.
- Select the required WLAN identification option to be displayed. For example, Name or SSID.
- Click OK.
