Traffic Analysis
You can analyze network traffic for APs, WLANs and clients.
From the traffic analysis tab, you can choose to analyze data using the following filters:
- Channel Range
- Total
- 2.4GHz
- 5GHz
- Throughput
- TX+RX—Number of bytes sent and received
- TX—Number of bytes sent
- RX—Number of bytes received
- Group
The parameters are displayed as Graphs and Bar Charts. When you hover over the graph you can view the Date and Time, Median, Likely Range, Min-Max Range of the parameters. To view specific information on the graph, click and drag the portion. The selected portion would zoom in. To restore to normal view, click the Reset zoom button.
