In addition to backing up the configuration file
manually, you can configure the controller to export the configuration file to an FTP server
automatically whenever you click Backup.
Follow these steps to back up the configuration file to an FTP server
automatically.
Go to .
Select the Configuration tab.
In Auto Export Backup, you can configure the controller to export the configuration
file to an FTP server automatically whenever you back up the configuration file.
- In Auto Export Backup, click Enable.
- FTP Server: Select the FTP server to which you want to export the backup file.
- Click Test. The controller attempts to establish connection
to the FTP server using the user name and password that you supplied. If the
connection attempt is successful, a success message is displayed. If the connection
attempt is unsuccessful, verify that the FTP server details (including the user name
and password) are correct, and then click Test again.
- Click OK.
After you verify the controller is able to connect to the FTP server successfully,
click OK to save the FTP server settings.
You have completed configuring the controller to export the configuration backup file to
an FTP server.
