Backing up Cluster Configuration
Ruckus strongly recommends that you back up the controller database periodically. This will help ensure that you can restore the system configuration settings easily if the database becomes corrupted for any reason.
The following are backed up in the system configuration backup file:
| Configuration Data | Administration Data | Report Data | Identity Data |
| AP zones | Cluster backup | Saved reports | Created profiles |
| Third-party AP zones | System configuration backups | Historical client statistics | Generated guest passes |
| Services and profiles | Upgrade settings and history | Network tunnel statistics | |
| Packages | Uploaded system diagnostic scripts | ||
| System settings | Installed licenses | ||
| Management domains | |||
| Administrator accounts | |||
| MVNO accounts |
A system configuration backup does not include control plane settings, data plane settings, and user-defined interface settings.
