        Go to .
        Select the Configuration tab.
        In Schedule Backup, you can configure the controller to backup its configuration
          automatically based on a schedule you specify.
            - In Schedule Backup, click Enable.
- In Interval, set the schedule when the controller will automatically create a backup
              of its configuration. Options include: Daily, Weekly and Monthly.
- Hour: Select the hour of the day when the controller must generate the backup.
- Minute: Select the minute of the hour.
- Click OK.
You have completed configuring the controller to create a backup automatically.
