Configuring the Data Plane
By default, the controller sends traffic from its data plane from a single interface.
(This feature is supported only in SZ300 and vSZ-H controllers)
If your organization's network requires separation of the access and core traffic, configure access and core separation on the controller.
To configure a data plane:
- Go to System > Cluster > Data Planes.
- Select the data plane from the list and click Configure. The Edit Data Plane Network Settings form appears.
- Configure the settings as explained in Table 8.
- Click OK.
| Field | Description | Your Action |
| Network | ||
| Interface Mode | Indicates the traffic direction. | Choose the option:
| Network > Primary (Access) Interface | ||
| IP Mode | Indicates the mode of assigning the IP address to this interface. | Select the option:
| Network > IPv6 Primary (Access) Interface | ||
| Network > Secondary (Core) Interface (applicable for Interface Mode: Access and Core Interfaces) | ||
| IP Address | Indicates the IP address of the core network interface. | Enter the IP address.
NOTE The secondary/core interface IP address must be configured manually; DHCP is unsupported.
| Subnet Mask | Indicates the IP address of the subnet mask. | Enter the subnet mask. |
| VLAN | Indicates that the traffic is tagged with a VLAN ID. | Enter the VLAN ID.
NOTE If VLANS are configured on both the access and core networks, the VLAN ID that you enter here must be different from the one that you entered for the primary/access interface.
NOTE You cannot configure the IP address and VLAN settings for a virtual Data Plane from the Primary (Access) and Secondary (Core) Interface sections. Only vSZ-H supports virtual Data Plane.
| Disconnect AP when core link down | Indicates that the AP is disconnected secondary core link is down. | Select the check box. |
| Static Routes | ||
| Network Address | Indicates the destination IP address of this route. | Enter the IP address. |
| Subnet Mask | Indicates a subnet mask for the IP address. | Enter the subnet mask. |
| Gateway | Indicates the IP address of the gateway router. | Enter the IP address of the gateway router. |
| Add | Adds the static route settings. | Click Add. |
| CALEA Relay | ||
| Mark this Data Plane as CALEA Relay (This feature is supported only for vSZ-E and vSZ-H controllers) | Indicates that the data plane uses CALEA relay. | Select the check box. |
| DHCP Profile | ||
| DHCP Profile | Indicates the data plane DHCP service profile. | Choose the DHCP service profile from the drop-down. |
| NAT Profile | ||
| NAT Profile | Indicates the data plane NAT service profile. | Choose the NAT service profile from the drop-down. |
| Syslog | ||
| Enable DHCP syslog | Enables syslog to record the DHCP logs. | Select the check box. |
| Enable NAT syslog | Enables syslog to record the NAT logs. | Select the check box. |
| Syslog Server IP | Indicates the IP address of the remote syslog server. | Enter the IP address of the remote syslog server. |
| Syslog Server Port | Indicates the port number of the remote syslog server. | Enter the Port number of the remote syslog server. |
You can restart a data plane. To do so, select the data plane from the list and click
Restart.
