Backing Up Configuration from the Web Interface
- For information on how to back up the controller configuration to an external FTP server automatically, see Backing up Cluster Configuration.
- In Auto Export Backup, click Enable.
- In FTP Server, select the FTP server to which you want to export the backup file.
Click Test. The controller attempts to establish connection to
the FTP server using the user name and password that you supplied. If the connection
attempt is successful, the following message appears: FTP server connection
established successfully.
If the connection attempt is unsuccessful, verify that the FTP server details (including the user name and password) are correct, and then click Test again.
- After you verify the controller is able to connect to the FTP server successfully, click OK to save the FTP server settings.
Parent topic: Backing Up Configuration
