You can synchronizing the license data, import a license file into the controller if it is unable to connect to the
Ruckus SmartLicense system and release licenses bound to an offline controller by downloading a copy of the licenses.
Go to
Select the
Installed Licenses tab.
You can view the following information about the licenses you have uploaded to the controller:
- Name: The name of the node to which the license was uploaded
- Node: Displays the name of the node
- Start Date: The date when the license file was activated.
- End Date: For time-bound licenses, this column shows the date when the license file expires.
- Capacity: The number of units or license seats that the license file provides.
- Description: The type of license.
