Managing Licenses
Depending on the number of Ruckus APs that you need to manage with the controller, you may need to upgrade the controller license as your network expands.
The maximum number of access points that the controller can manage is controlled by the license file that came with the controller. If the number of access points on the network exceeds the limit in the license file, you will need to obtain an additional license file and upload it to the controller.
For information on obtaining additional license files, contact
Ruckus Support Team or an authorized
Ruckus reseller.
The maximum number of access points that a license supports depends on its stock-keeping unit (SKU).
