Generating Certificate Signing Request (CSR)
If you do not have an SSL certificate, you will need to create a certificate signing request (CSR) file and send it to an SSL certificate provider to purchase an SSL certificate.
To create a CSR file:
	 - From the application select, System > Certificates > CSR.
 - Click Generate, the Generate CSR form appears.
 - Enter the following details:
- Name—A name for this CSR.
 - Description— A short description for this CSR.
 - Common Name—A fully qualified domain name of your Web server. This must be an exact match (for example, www.ruckuswireless.com).
 - Email—An email address (for example, [email protected]).
 - Organization—Complete legal name of your organization (for example, Google, Inc.). Do not abbreviate your organization name.
 - Organization Unit—Name of the division, department, or section in your organization that manages network security (for example, Network Management).
 - Locality/City—City where your organization is legally located (for example, Sunnyvale).
 - State/Province—State or province where your organization is legally located (for example, California) Do not abbreviate the state or province name.
 - Select the Country
 - Click OK, the controller generates the certificate request. When the certificate request file is ready, your web browser automatically downloads it.
 - Go to the default download folder of your Web browser and locate the certificate request file. The file name is myreq.zip.
 - Use a text editor (for example, Notepad) to open the certificate request file.
 - Go to the website of your preferred SSL certificate provider, and then follow the instructions for purchasing an SSL certificate.
 - When you are prompted for the certificate signing request, copy and paste the entire content of myreq.csr, and then complete the purchase.
 - After the SSL certificate provider approves your CSR, you will receive the signed certificate via email.
 - Copy the content of the signed certificate, and then paste it into a text file.
 - Save the file.
 You can also edit, clone, download or delete a CSR by selecting the options Configure,
		Clone,
		Download or
		Delete respectively.
