If no tunneled WLANs exist in the zone, you can
change the tunnel type from SoftGRE to GRE or GRE + UDP.
MVNO accounts are currently unsupported by SoftGRE tunnels. If you create an MVNO
account and assign an AP zone that is using a SoftGRE tunnel, an error message
appears.
Follow the steps as described in Monitoring WLAN Services to change the tunnel type from SoftGRE.
Scroll down to the AP GRE Tunnel Option section.
In AP Tunnel Type, select the tunnel type to which you want to
change from SoftGRE.
If you attempt to change the tunnel type when a tunneled WLAN exists within the zone,
the following error message appears:
Unable to update the configuration of the AP zone. Reason: It is disallowed to change the tunnel type, because it
has tunneled WLAN.
Click OK.
The zone configuration information is displayed.
Figure 230
Monitoring Zone Configuration
