To delete a target active cluster form active-active cluster redundancy mode, perform these steps.
		   Go to
		   The
			 Cluster page appears.
		   Select the cluster, scroll down and click the
			 Configuration tab.
		  On the right side of the
			 Configuration area, click
			 Configure.
		   The
			 Edit Cluster page appears.
		  In the Cluster Redundancy area, click the
			 Enable Cluster Redundancy option, if this option is enabled and the button appears blue in color.
		   In
			 Type, choose
			 Active-Active.
		  From the Target Active Cluster list, select the cluster and click
			 Delete.
		   You have deleted cluster redundancy form the target active cluster.
