Locating a Rogue Access Point
You can identify the estimated location area of a rogue AP on a map. Managed APs that detect the rogue APs are also visible in the map.
 To locate the Rogue AP:
	 - From the left pane, click Report and Rogue Access Points. The Rogue Access Points page appears.
		   Select the Rogue AP from the list and click Locate Rogue. The Rogue AP Location pop-up window appears locating the rogue AP.
				 You can select:
						Map-to view the location in street view
						Satellite-to view the location as satellite imagery
						+-to zoom in the location
						--to zoom out the location.
				 You can find the following information:
				  - Rogue APs: MAC, Type, and SSID
- Detecting APs: MAC, Name, and RSSI
				 You can select:
- Click OK.
