To create a traffic class profile, you must define the basic required settings.
		  Go to
		   Select the
			 Traffic Classes tab, and then select the zone for which you want to create the profile.
		  Click
			 Create.
		    The
			  Create Traffic Class Profile page appears.
			  Figure 134
             Creating a Traffic Class Profile
		  Under
			 General Options, enter traffic class profile name and description.
		  Under
			 Traffic Classes, click
			 Create to add a traffic class.
			 NOTE  Only four traffic classes can be added in a single
				 Traffic Class profile.
Figure 135
		  Enter the name of the traffic class profile.
		  In the
			 Access Control Rule Entry field, enter an access control rule in the proper format.
		  Click
			 Add to add an access control rule or click
			 Import CSV to import an access control list.
			 NOTE  Click the
				 Import CSV arrow and select
				 Download Sample (CSV) to download the CSV template.
NOTE  To delete an access control rule, select an entry and click
				 Delete.
		  Click
			 OK.
You have created a Traffic Class Profile.
 IP destination is reachable only when IP is not part of Traffic Class, but present under Split Tunnel. Split-tunnel policy is effective only when both
Split Tunnel and
Traffic Class features are enabled together.
