ICX Switch Configuration and Behavior
- ICX Switch Behavior with SmartZone
- Enabling an ICX Device to be Managed by SmartZone
- Displaying the SmartZone Connection Status
The status of the ICX switch connection with SmartZone can be displayed using the show sz status command. - Disconnecting the Switch Connection with SmartZone
The sz disconnect command can be used to disconnect the ICX switch from the current connection with SmartZone and initiate a new connection based on the currently available list of SmartZone IP addresses. - Disabling SmartZone Management on the ICX Switch
When SmartZone management is disabled on the switch, the switch will not initiate a connection with SmartZone even if a SmartZone IP address is available.
