You can disable a current target cluster in an active-active cluster redundancy mode. To do so, perform these steps:
Go to
The
Cluster page appears.
Select the cluster, scroll down and click the
Configuration tab.
On the right side of the
Configuration area, click
Configure.
The
Edit Cluster page appears.
In the Cluster Redundancy area, click the
Enable Cluster Redundancy option to switch off the option.
Click
OK.
You have disabled cluster redundancy form the current target active cluster.
