SCI Thresholds for each AP
The following are the thresholds from SCI for each AP.
The below thresholds provided is based on per AP model.
| Resource | Low Threshold | Normal Threshold Range | High Threshold Range |
| CPU | Less than 25% | Between 25% to 75% | Greater than 75% |
| Memory | Less than 2GB | Between 2GB to 8GB | Higher than 8GB |
| Hard Disk | Less than 50GB | Between 50GB to 100GB | Higher than 100GB |
