Assigning Certificates to Services
You can map certificates to services
To specify the certificate that each secure service will use:
- From the application select, System > Certificates > Service Certs.
 - Select the certificate that you want to use for each of the following services:
- Management Web—Used by Web UI and Public API traffic.
 - AP Portal—Used by Web Auth WLAN and Guest Access WLAN control traffic.
 - Hotspot (WISPr)—Used by WISPr WLAN control (Northbound Interface, Captive Portal, and Internal Subscriber Portal) traffic.
 - Communicator—Used by AP control traffic.
 - To view the public key, click View Public Key, the Certificate Public Key form appears with the public key.
 - Click OK.
