After you create a configuration backup, you have
the option to download the backup file from the System Configuration Backups
History section.
Go to .
Select the Configuration tab.
Locate the entry for the backup file that you want to download. If multiple backup
files appear on the list, use the date when you created the backup to find the backup
entry that you want.
Click Download.
Your web browser downloads the backup file to its default download folder. NOTE: When
your web browser completes downloading the backup file, you may see a notification at the
bottom of the page.
Check the default download folder for your web browser and look for a file that
resembles the following naming convention: {Cluster
Name}_BackupConf_{MMdd}_db_{MM}_{dd}_{HH}_{mm}.bak
For example, if the controller cluster is named Cluster A and you created the
configuration backup on September 7 at 11:08 AM, the backup file name will be:
ClusterA_BackupConf_0907_db_09_07_11_08.bak
You have completed downloading a copy of the configuration backup.
