The Hotspot 2.0 technology allows users to
    seamlessly roam between the provider's home Wi-Fi network and the visited Wi-Fi network in a
    different location. A Wi-Fi provider can partner with several roaming partners to provide Wi-Fi
    access to partner's subscribers. Public venues such as institutions, restaurants, and stadiums
    are considered roaming partners.
        Go to .
        Select the Hotspot 2.0 tab, and then
          select the zone for which you want to create the profile.
        Click Create.
         The  Create Hotspot 2.0 Venue Profile page appears. Figure 116
            Creating a Hotspot 2.0 Venue Profile
        Configure the following:
            - Name: Enter a name for this venue profile. This name identifies the venue profile
              when assigning an HS2.0 service to a HS2.0 venue.
- Description: Enter a description for the venue profile.
- Venue:
                - Venue Names: Create a new venue name. Select the language and enter the venue
                  name in that language.
- Venue Category: Select venue group and venue type as defined in IEEE802.11u,
                  Table 7.25m/n.
- WAN Metrics: Provides information about the WAN link connecting an IEEE 802.11
                  access network and the Internet; includes uplink/downlink speed estimates
 Select the operator profile. This name identifies the service operator when
              assigning an HS2.0 service to a HS2.0 WLAN.
        Click OK.
You have completed creating a Hotspot 2.0 WLAN profile.
 You can also edit, clone
        and delete a Hotspot 2.0 venue profile by selecting the options
Configure,
Clone and
Delete respectively, from the
Venue Profile
        section in the
Hotspot 2.0 tab.
