Viewing Cluster Configuration
After you have configured cluster redundancy, you can view details of the active and standby clusters.
Cluster redundancy is supported only on SZ300 and vSZ-H.
Follow these steps to view the cluster configuration:
- Go to System > Cluster. The Cluster page appears.
Select the cluster, scroll down and click the
Configuration tab. You can view the cluster details listed in the following table.
Table 16 Cluster Details Field Description Active Cluster Standby Cluster Cluster Configuration IP Support
Displays IP support version Yes Yes Cluster Redundancy Status Displays the cluster redundancy status. Yes Yes Cluster IP list Displays cluster name, management IPs, and control IPs of standby cluster. Yes No Schedule Configuration Sync - Status—Displays sync status
- System Time Zone—Displays the system time zone set
- Time—Displays the sync time followed everyday
- Last Trigger Time—Displays the date and time the clusters synced last. Applies to both scheduled sync or manually sync
- Next Trigger Time—Displays the date and time of the next scheduled sync
- Sync Now—Triggers manual configuration sync operation
Yes No State Displays the system configuration sync state. Yes No Progress Status Displays the progressive status of the system configuration sync. Yes No
Parent topic: Cluster Redundancy
