Configuring NAT Pool Setting
- Go to Services & Profiles > DHCP & NAT > NAT Profiles (DP).
- Select the NAT profile from the list and click the Pools tab.
- Click Create, the Create Pool Configuration page appears.
		   Configure the following:
			 -  General Options
						Pool Name: Type a name for the NAT pool settings that you want to create.
						Description: Type a description for the pool settings that you want to create.
				  Policy Options
						Private VLAN Range: Type the VLAN range and click Add. Range: 1 through 4095. For example: 1 or 1-2.
						Private QinQ VLAN Range: Type SVLAN range, CVLAN range and click Add. Range: 2 through 4095. For example: 2 or 2-3.
				  Translation Options
						Port Range: Type the port range. Range: 10000 through 65534. For example: 10000-20000.
						Public Address Range: Type the public address range. Note: This public address must not be duplicated with the other public address in the same subnet, which includes applied NAT Profile and vSZ-D's Access and Core Interface Address.
-  General Options
- Click OK. You have created a NAT pool setting.
