| Community | Indicates that applications which send SNMP Get-Requests to the controller
                    (to retrieve information) will need to send this string along with the request
                    before they will be allowed access. | Enter a name. |
                  | Authentication | Indicates the authentication method. | Choose the required option:
                      None—Use no authentication.SHA—Secure Hash Algorithm, message hash function with 160-bit
                          output.
                          Enter the Auth Pass Phrase.Choose the Privacy option.
                              None: Use no privacy method.DES: Data Encryption Standard, data block cipher.AES: Advanced Encryption Standard, data block cipher.Enter a Privacy Phrase, 8 through 32 characters.MD5—Message-Digest algorithm 5, message hash function with 128-bit
                          output.
                              None: Use no privacy method.DES: Data Encryption Standard, data block cipher.AES: Advanced Encryption Standard, data block cipher.Enter a Privacy Phrase, 8 through 32 characters. |
                  | Privilege | Indicates the privileges granted to this community. | Select the required privileges:
                      Read—Privilege only to read.Write—Privilege only to read and write.Notification—Privilege to:
                          Trap—Choose this option to send SNMP trap notification.Inform—Choose this option to send SNMP notification.
                          Enter the Target IP address.Enter the Target Port number.Click Add. |
