Creating a User Defined Application
When an application is unrecognized and generically (or incorrectly) categorized, the controller will be unable to monitor its traffic, unless you configure an explicit application identification policy based on IP address/mask, port and protocol.
To configure a user-defined application:
    You have created the user defined application.
 You can also edit, clone and delete
        the application policy by selecting the options Configure,
          Clone and Delete respectively, from the
          User Defined tab.
