Configuring SNMP v2 Agent
To configure SNMP v2 Agent settings:
- Go to System > General Settings > SNMP Agent.
- Select the Enable SNMP Notifications Globally check box to send out notification messages.
- To configure the SNMPv2 Agent, click Create and update the details as explained
          in the following table.
Table 6 SNMP v2 Agent Settings Field Description Your Action Community Indicates that applications which send SNMP Get-Requests to the controller (to retrieve information) will need to send this string along with the request before they will be allowed access. Enter a name. Privilege Indicates the privileges granted to this community. Select the required privileges: - Read—Privilege only to read.
- Write—Privilege only to read and write.
- Notification—Privilege to:- Trap—Choose this option to send SNMP trap notification.
- Inform—Choose this option to send SNMP notification.
 - Enter the Target IP address.
- Enter the Target Port number.
- Click Add.
 NOTEYou can also edit or delete an SNMPv2 agent. To do so, select the SNMPv2 agent from the list and click Configure or Delete respectively.
- Click OK.
