You can also edit the WLAN configuration to select a WiFi calling profile.
		   Go to
			 Wireless LANs.
		   Select the WLAN for which you want to enable WiFi calling and click
			 Configure.
		   The
			  Edit WLAN Configuration page appears. You can also enable WiFi calling when you create a fresh WLAN configuration, by clicking
			  Create.
			  Figure 148
            Configuring WiFi Calling in a WLAN
		   In
			 Advanced Options, move the
			 WiFi Calling radio button to ON. WiFi calling is enabled.
		   Click
			 Select.
		    The
			  WiFi Calling Policies page appears.
			   From the list under
				Available Profiles, identify the ones you want and click the
				-> icon. The profile(s) is moved under
				Selected Profiles. You can use the
				<- icon to de-select the profile for the WLAN.
		   Click
			 OK.
		    The profile(s) selected are displayed under the
			 WiFi Calling Profile
			 field.
 You have selected the WiFi calling profile that you want to apply to the WLAN.
