You must create an application policy to limit traffic by application, to classify traffic into priority queues using QoS traffic shaping rules, or to completely block access to an application.
	 Complete the following steps to create an application control policy:
		  Select
		  Click the
			 Application Policy tab.
		   The
			  Application Policy page appears.
			  Figure 122
            Viewing Application Policy
		  Click
			 Create.
		    The
			  Create Application Policy page appears.
			  Figure 123
             Creating an Application Policy
		  Under
			 General Options, enter a policy name and policy description.
		  Under
			 Rules, click
			 Create to create a new rule.
			 NOTE  Each application policy can contain up to 128 rules.
 The
			 Create Application Policy Rule page appears.Figure 124
             Creating an Application Policy Rule
		  In the
			 Rule Type field, select one of the following options:
				- Denial Rules
- QoS
- Rate Limiting
		  In the
			 Application Type field, select the type of application.
		  In the
			 Application field, select the application for which you want to create a policy rule.
			 For example, if you select
			 All in the application category and save the application rule, the application rule list reflects all Antivirus applications and is selected as a single entry in the rule list. A full category is counted as one rule in the allotment of 128 Layer 7 rules in a Layer 7 policy.
		  Click
			 OK to save the rule.
			 If a rule is already created, you can edit its configuration settings by selecting the rule and clicking
			 Configure on the
			 Create Application Policy page.
		  Under
			 Logging, select the appropriate option for the APs to log events:
			 - Allow the AP to log every application event and end the events to SmartZone
- Allow the AP to log every application event and end the events to external syslog
		  Click
			 OK to save the application control policy.
You have created an application control policy.
		You can continue to apply the application control policy to user traffic, as described in
Implementing an Application Control Policy.
