Limiting the AP count for a Zone in a Partner Domain
To limit the number of AP count for a zone in a partner domain:
- Create a super admin account for the partner domain. See the Administrating the Controller chapter.
Create a user group and configure the access permissions, resources and administrator account. Refer Creating User Groups.NOTEWhile creating user groups, in step 4 (I) c, for Permission, select Super Admin from the drop-down.
Log on to the controller web interface using the following logon details:
- User Name:
Account Name@Domain
The Account Name that you set when you created the Administrator Account and the Domain for which you created the Administrator Account. For example: If the partner domain is TestDomain and the Account Name is User, then the User Name isUser@TestDomain
- Password : The password that you set when you created the Administrator Account.
- User Name:
Follow the procedure to limit the number of APs for a zone in a partner-domain:
- Go to System > AP Settings > AP Number Allocation.
- Select the Enable AP Number Allocation check box and click OK. The Settings bar appears.
- From the left pane, in the system tree hierarchy, select the partner-managed zone for which you want to set the AP number limit.
On the right pane, perform one of the following procedure:
- Select Share Mode
- Enter Number Limit
- Click OK.
Parent topic: Limiting the Number of APs in a Domain or Zone
