Monitoring Cluster Settings
This section provides information on how to view the status of the cluster settings.
You can select the following tabs for more information:
- Summary—Details such as Name, model, serial number, bandwidth, data driver, number of core, data interface details, management interface details, IP details, memory usage, disk usage.
- Network Settings—Details such as control interface, cluster interface, management interface, DNS Server, Routes. Appears only for Control Plane.
- Configuration—Details such as physical interfaces, User defined interfaces, Static Routes Interface.
- Traffic & Health—Details on historical or real-time data such as CPU usage, memory usage, disk usage, interface, port usage for Control Planes and only CPU usage, memory usage, and port usage for Data Planes.
- System—Details of process name and its health status. Appears only for Data Plane.
- Alarm—Details of alarms generated. You can Clear Alarm or Acknowledge Alarm that are generated.
- Event—Details of events that are generated.
- DP Zone Affinity—Details of the data plane, for example: name, profile version, version match info, DP count and description. Appears only for Data Plane.
