Configuring NAT Global Settings
 To create a NAT global setting:
	 - Go to Services & Profiles > DHCP & NAT > NAT Profiles (DP).
- Click Create, the Create NAT Profile page appears.
		   Configure the following:
			 - Profile Name: Type a name for the NAT profile that you want to create. AP supports 32 bytes.
				  Description: Type a description for the profile that you want to create.
				  Subnet: Type the IP address.
				  Prefix: Type a prefix value. Maximum range: 31.
				  Public VLAN: Type the VLAN range. Range: 2 through 4095.
				  Gateway: Type the gateway IP address.
- Click OK. You have created a NAT Profile.
Parent topic: Creating Profile-based NAT
