Creating a Split Tunnel Profile
Complete the following steps to configure a split tunnel profile:
  1. Select Services & Profiles > Tunnels and Ports.
  2. Select the Split Tunnel tab, and then select the zone for which you want to create the profile.
  3. Click Create.
    The Create Split Tunnel Profile window is displayed.
    Figure 161  Creating a Split Tunnel Profile
  4. Enter the split tunnel profile information:
    RuckusGRE or SoftGRE must be enabled on the WLAN before mapping it to a Split Tunnel Profile.
    1. In the Name field, type a name for the split tunnel profile.
    2. In the Description field, type a short description for the split tunnel profile.
    3. In the IP Address field, enter the destination IP address.
    4. In the Subnet Mask field, enter the destination IP subnet mask.
    5. Click Add to add the destination IP details.
    6. Click OK.
You can also edit, clone or delete the profile by selecting the options Configure, Clone, and Delete respectively from the Split Tunnel tab.
