Managing WLANs
When you select a System, Zone, or WLAN Group from the hierarchy tree, respective contextual tabs appear at the bottom of the page.
These tabs are used to monitor the selected group. The following table lists the tabs that appear for System, Zone, and WLAN Group.
Table 21 System/Zone/WLAN Groups Monitoring Tabs
Tabs Description System Zone WLAN Groups
Configuration Displays the respective configuration information. Yes Yes Yes
Traffic Displays the respective historical traffic information. Yes Yes Yes
Alarm Displays the respective alarms information. Yes Yes Yes
Event Displays the respective event information. Yes Yes Yes
APs Displays the respective AP information. Yes Yes NA
Clients Displays the respective client information. Yes Yes NA
Services Displays the respective Services information. Yes Yes NA
Administrators Displays the respective administrator account information. Yes NA NA
When you can select a Zone and click More you can perform the following operations:
  • Extract WLAN Template
  • Apply WLAN Template
  • Change AP Firmware
  • Switchover Cluster
