Monitoring Access Points
When you select an AP from the list, contextual tabs appear at the bottom of the page.
The following table helps you to understand the real-time information about the AP.
| Tabs | Description |
| General | Displays group information |
| Configuration | Displays group configuration information. |
| Health | Displays historical health information. |
| Traffic | Displays historical traffic information. |
| Alarm | Displays alarm information. |
| Event | Displays event information. |
| Clients | Displays client information. |
| Pool Stats | Displays DHCP pool data. |
| Stats Counter | Displays AP statistics that can be exported to CSV format. |
Additionally, you can select an AP and click
More to perform the following operations as required:
- Select ALL - Selects all the APs in the list.
- Deselect All- Clears all selection from the list.
- Troubleshooting > Client Connection - Connects to client devices and analyze network connection issues in real-time. See, Troubleshooting Client Connections
- Troubleshooting > Spectrum Analysis - Troubleshoots issues remotely, identify sources of interferences within the network and allow administrators access to the RF health of the network environment. See, Troubleshooting through Spectrum Analysis
- Restart - Restarts an access point remotely from the web interface.
- Lock - Disables all WLAN services on the AP and disconnect all wireless users associated with those WLAN services temporarily.
- Unlock - Makes all WLAN services available.
- Import Batch Provisioning APs - Import the provisioning file. See, Options for Provisioning and Swapping APs
- Import Swapping APs - Manually trigger the swapping of two APs by clicking the swap action in the row. See, Options for Provisioning and Swapping APs
- Export All Batch Provisioning APs Downloads a CSV file that lists all APs that have been provisioned.. See, Options for Provisioning and Swapping APs
- Export All Swapping APs - Downloads a CSV file that lists all APs that have been swapped. See, Options for Provisioning and Swapping APs
- Download Support Log - Downloads support log.
- Trigger AP Binary Log - Triggers binary log for the selected AP.
- Download CM Support Log - Downloads Cable Momdem support log.
- Restart Cable Modem - Restarts the cable modem. The AP will disconnect from the network for a short period. The AP will disconnect from the network for a short period.
- Reset Cable Modem - Resets the cable modem.
- Reset Cable Modem to Factory Default - Resets the cable modem to factory default settings.
- Untag Critical APs - Stating APs as non-critical. See, Tagging Critical APs.
- Swap - Swaps current AP to swap-in AP. See, Editing Swap Configuration
- Switch Over Clusters - Moves APs between clusters. See Configuring AP Switchover.
- Approve - Approves AP and completes registering. See, Working with AP Registration Rules.
