Location Service
If your organization purchased the Ruckus Smart Positioning Technology (SPoT) location service, the controller must be configured with the venue information that is displayed in the SPoT Administration Portal.
After completing purchase of the SPoT location service, you will be given account login information that you can use to log into the SPoT Administration Portal. The Admin Portal provides tools for configuring and managing all of your venues (the physical locations in which SPoT service is deployed). After a venue is successfully set up, you will need to enter the same venue information in the controller.
  1. Select System > General Settings > Location Service.
    The Location Service page appears.
    Figure 24  Location Service
  2. Click Create.
    The Create LBS Server page appears.
    Figure 25  Creating an LBS Server
  3. In the Venue Name field, enter the venue name for the server.
  4. In the Server Address field, enter the venue name for the server.
  5. In the Port field, enter the port number to communicate with the server.
    Default port number is 8883.
  6. In the Password field, enter the password to access the server.
  7. Click OK.
You have completed creating a location-based service on the controller.
You can also edit, clone, and delete the location service by selecting the options Configure, Clone, and Delete respectively from the Location Services tab.
