JavaScript must be enabled in order to use this site.Please enable JavaScript in your browser and refresh the page. Deleting Switches You can delete switches that you do not want the SmartZone controller to manage anymore. From the left pane, select Switches. The ICX Switches page appears. Select the switch you want to delete and click Delete. The selected switch is deleted, and it will not be managed by the SmartZone interface. Parent topic: SmartZone Switch Management
